no way to get "pdf reports"
Repetier-Server 1.0.4 on PI
i enable in printer configuration below firmware settings - "Log all Printe in a History Database".
i enable in global settings->Print Reports "keep reports of last year"
i enable webcam snapshot to report
i applay
I make a new print
at the end of the print go in history but i don't see a new pdf button to view the report.
connect via ssh and in "/ var / lib / Repetier-Server / reports" there are no pdf reports.
i make a new fresh installation on new sd.
i try all variants "do not delete reports"/"keep last 500 reports"/"keep reports of last year"
i try enable/disable webcam snapshot.
the result is always the same no pdf report is generated.
Where am I doing wrong?
thank you
PDFs will only created for new successful prints in that case.
Does creating snapshots work? I recently detected that when webcam was not available the creation of pdfs failed. Should be fixed in 1.0.4. In my test installation it is working that way. Here I have set to keep last 500 reports. Keep last year might be a problem on pi where the clock is reset after restart until it reaches a time server.
No currently you can't see how much are left. But if you get message that all are used up and you have less installations just drop us a message and we reset it. But if you always deactivate before deleting a installation you get the count back on your own.
