Group default invalid character
When I want to upload file from my slicer, i've seen a character error on the group selection field. default is written "Défaut"
is it prusaslicer or Repetier-server fault ?
Regards,
Edouard
Regards,
Edouard
All names should be send as UTF-8 so it works on all os the same. If it is a group of you containing non ascii it might be prusaslicer using a different font for viewing. But the original "Default" is ascii only and must be identical on all devices.
My locale are in french.
For linux locale is C. On windows not. So again where do you run Repetier-Server?
When you are in regular GUI do you see the correct Name?
For testing I switched PrusaSlicer to french. Then Default becomes "Dèfaut". More similar to what you see. Since server sends # that name comes from PrusaSlicer and it is most likely a problem with charset. Either in translation file it is wrongly encoded (also it is working for mac) or decoding in your os uses wrong encoding. Have you updated prusaslicer to latest version? I remember a similar problem with russion text in one of the prusa threads.
Server (pro 1.0.3) is on debian 10. prusasclicer (vers 2.3) is on windows 10.
