Repetier Host not "seeing" printer in COM Ports.
Hello all, I have an ANet A8 printer, bog stock, a few years old.
I am having an issue with Repetier Host in that it does not "see" my printer when I connect it to my PC. I am running an old Pentium 4 computer running Windows 7 that I have and would prefer to keep it that way. I have done the "unplug and refresh" method and no COM port appears or disappears in that process. I have set the software up as I have done with prior computers, with checking the "ping pong" box and setting the Baud rate to 115200. When I plug the printer in I get the usual "drivers not available" prompt and am able to look at the printer in Device manager as a "USB 2.0 Serial device." I have tried other USB ports, and a hub to see if that changes anything and no dice.
The printer is confirmed to work a Core Duo laptop and previously a Core2Duo laptop (that died) through this method, but Repetier doesn't want to play nice with either of my Pentium 4 computers.
Any advice or things I am missing?
Thanks, AfterDark3
Thanks, AfterDark3
