1x RPi 3 + 2x Prusa i3MK3S+ = Layershift?
i bought a license of the repetier server and it runs on a RPI 3 connected to a 7" Touchscreen and it operating 2 Prusa i3mk3s+ but I have a problem.
After a while i get a layershift on the prints, if I start it from the SD not connected to the Server everything is fine.
Now is my question is the RPi 3 not powerful enough, should I upgrade to a RPi 4? Do you have any recommandations?
Sincerly
But recently I also got sometimes a shift which never happened before so wonder if they changed something in firmware (did update recently) or slicer settings. In slicer with their configs they explicitly set some physical parameters like acceleration.
In any case it is no server power problem. The path planning in printer firmware even considers that no moves follow and slows down to not loose steps.
