Touchscreen: How to access files stored in Folders?
With the regular Web-Frontend ip:3344, I can store and access files at "Projects" and directly at the Printer.
On the LCD touchscreen connected directly to the Raspberry, I cannot find a way to access files organized in Projects.
Only files stored directly at the printer are visible.
What am I doing wrong?
  • Nothing. Projects are not accessible in touch screen. They are meant as input for upcoming slicer which will only be available on main gui.
    That said, you might add an upload folder that points to the projects folder. Then you can use the same function to read from usb stick and browse through project directory tree and get the gcodes from there. Only drawback is that is only works with the local server and not with connected local cloud servers having projects.
