pressure chamber sensor
hello people i have a question. I connected a dht11 sensor via an ESP8266. can I somehow tap this and use it as a pressure chamber temperature sensor?
  • Assuming you run linux then under /var/lib/Repetier-Server/scripts is a script named hardware_info - it reports several os values to server. You can extend it to read the pressure and output it there. This would then appear in the bolt icon menu. But there is nothing you can do with it - it is just informational.
  • edited February 2021
    That sounds great. How can I now integrate a dht11 temperature sensor into this file in the file so that the pressure chamber temperature already specified is also specified !?
    if the answer i can get with:
    answer is:
    • "StatusSNS": {
      • "Time": "2021-02-10T00:37:50",
      • "DHT11": {
        • "Temperature": null,
        • "Humidity": null,
        • "DewPoint": null
      • "TempUnit": "C"
    I want to read out this sensor
    null is only show because sensor is not connected
  • I guess you should use curl to get answer, store it in a variable and then use grep or awk to filter the value form the answer and then echo it in the script in same format. Here some description to adjust icons:
    tests for $database/scripts/hardware_info rsp. hardware_info.bat/.exe
    Return format is a tab separated List of data to return:
    1. Name shown
    2. Msg type: 0 = text, 1 = int value, 2 = 1 digit info, 3 = 2 digit info, 10 = splitter, 11 = Block Headline
    3. unit
    4. Value/Text
    5. Urgency: 0 = hidden, 1 = message, 2 = warning, 3 = error
    6. Icon
    7. URL for detailed description or empty
    object HardwareInfo {
      msgType: number,
      unit: string,
      text: string,
      value: number
      urgency: number,
      icon: number,
      url: string
    List of icons:
    0: None
    1: Bolt
    2: Temperature
    3: exclamation-triangle
    4: Battery
    5: Bug
    6: Plug
    7: Usb logo
    8: Camera
    9: Tasks
    10: Bell
    11: Bluetooth
    12: Square
    13: Checked Square
    14: HDD
    15: Hourglass
    16: wifi
    17: Microchip
    18: Clock
