Printer Settings for Repetier Server Renkforce RF2000
Hello all,
recently I upgraded my RF 2000 to the latest Repetier Firmware, and I installed a fresh latest Repetier Server on a Raspi.
What Seetings should I define in the Printer Speds?
It's totally different like in the Printer Manual?
Does anyone has a running configuration file for this Printer?
The other speeds and max accelerations should be same as set in firmware configuration and can normally seen in eeprom settings. They are just used for best time estimate so if they differ nothing happens except timing is more off then otherwise.
