Temp graphs in the Control section not available
Hello
After using Repetier Server for one year and a bit more, i noticed in the manual, that should be temperatur graphs in the control section. But this graphs are not visible in my installation on a Raspberry Pi. I see just the regulators for the extruder and the heatbed. Are there some requirements to enable this graphs?
Printer: Prusa MK3S
  • Yes, there are switches below the knobs to tell server which graphs you want to see. I just wonder why you do not see the extruder, or do you? For extruder you can select current extruder or all extruder.
  • Ok, my fault... i thought the switches are to switch the extruder and the heatbed off.  :# I tested it in your live demo.
    Everything is fine, and sorry for my inexperience.
