Add small feed before change an filament and motoroff in control/Change filament
edited January 2021 in Feature Requests
Add small Slowly feed after heating (~10 mm -can be set like an other parametes) before retract filament in control/Change filament.
Add motoroff in the screen, also. If I change the filament I need to manually tuck it in a little bit, this is not possible if the motor is on.
  • In printer configuration there are scripts to run on insert and remove filament. Script are run before starting retract/undo distance. So here you can add extra gcodes to be called when you hit the button like motor off, wait then slow insert first or what ever you want.
