Repetier server not reconecting
Hi.
I have installed Rpetier Server on raspberry pi. Made 2 printer (both with MKS Robin E3D board). Everything working great, but only for the first time (just after I add the printer). When I turn off any printer, or just push ESTOP in Repetiet it's showing as connected but no communication. Server trying to get communication, but can't. To make it working once again I need delete printer, once again make a new one (or just upload config file) and it's working. But only till I turn off/reset the printer. I'm using Marlin 2.0.7.2
Is there anything I can change to make it working constantly?
But if i remove printer and upload config file communication starts almost in same time as i press "create" button. No matter what i have in DTR/RTS
The other thing is that first connection test is always run in ping-pong mode. So have you tried activating ping-pong for your printer? Does it connect better then?
