Repetier generates wrong GCodes
I have been trying using Cura in Repetier Host, but the codes generated doesn't have the M109, which is to wait for the extruder to reach the temperature. As a result, my printer started to print at 0°C then stops and complains that temperature is too low.
;Generated with Cura_SteamEngine 15.01
; Default start code
G28 ; Home extruder
G1 Z15 F100
M107 ; Turn off fan
G90 ; Absolute positioning
M82 ; Extruder in absolute mode
M190 S50
; Activate all used extruder
G92 E0 ; Reset extruder position
; Wait for all used extruders to reach temperature
;Layer count: 88
;LAYER:0
M107
G0 F6600 X70.428 Y100.925 Z0.300
;TYPE:SKIRT
G1 F1800 X85.375 Y100.925 E0.78113
G1 X85.375 Y89.525 E1.37689
G1 X108.347 Y89.525 E2.57741
Another problem, I own Geeetech A20T (3 extruders with single nozzle), but not matter which colour I choose, it always generate codes to print from the first extruder.
Will it be fixed soon or is there anything I should've done?
CuraEngine always starts with using first extruder. You can no only use second extruder. Using more then 2 is not really possible due to prima pillar handling.
Use PrusaSlicer instead - there you can use any extruder and also work with 3.
