Upon start of print - flow jumps to 95%
I discovered a strange bug (or have set up something wrong)...
I slice in PrusaSlicer and copy file to SD-card, start a print and everything works fine. I can see the same temperatures and flow as set up on the printer in repetier-server. I then take the same file and send it to the printer (Prusa i3 MK3S) via "Direktdruck" and after the prime line is printed the flow automatically jumps from 100% to 95% (on GUI, the printer and LCD)... If I abort the print, set flow to 100% and send file again - same procedure.
Did I miss a setting or why is this happening? A bug?
So is the flow really 95% of whatever value I set up before? I calibrate my filaments using the extrusion multiplier... is that the 95% value? Strange...
Just one thing... when printing from SD the web-GUI doesn't reflect the 95% change. That would be great to have so no one gets confused.
