Addition to Gcode Blocker
It would be great if the area selection could be extended to allow irregular shapes. If you have a packed buildplate you can only exclude rectangular areas, which limits the usefulness of the feature. The ability to click corners of a polygon would allow the user to select a failed part without hitting another part nearby. As it stands, you can only really use this feature if you have everything aligned in a grid. The algorithm used by Cura now places objects much closer together and maybe it's time that the blocker kept pace with that.
But even with a simple diagonal side, drawing lots of rectangles is at best a blunt solution compared to creating a simple outline. I just feel it would be a more elegant solution that adds value to the product.
