another thing i saw is a possible glitch with print speed factor. Last time i did a print job the regular view showed 90% but the front2 view showed 100% in the printer status. See the screenshots. Did this ever happen to you? Tested with Repetier Server 0.94.1 too.
Sure the touch screen is showing the correct printer here? Since you don't see the active printer it is easy to mismatch printers if you have more than one.
Also if same and you reload touch gui does it then show correct value?
