Hi to all could someone point me to the right direction,how to start with Klipper. Do i need Repetier Server,? or just Repetier Host. Thank you for your time. You talk to a complete newbie.
Only our Repetier-Server can communicate with klipper. Read also https://www.repetier-server.com/knowledgebase/klipper/ for a special problem with klipper permissions. You install all this on your pi (assume klipper still only works on pi).
You can then use in host the repetier-server connector to connect to server with klipper or use the native server gui in web browser and upload gcodes there (created with host for example).
Well second day and could not go over on main pages. Downloaded Repetier-Server image,loaded,look like working,but could not load printer.cfg and could not load Klipper. Any help would be appreciate. Thank you.
Make sure server is not using the serial of your board! Server talks with klipper using /tmp/printer I think it was and klipper communicates with server so klipper needs the serial. Then it should work.
<span></span>
