Basic Movement
Hi, I'm new to printing.  I have a Artillery Genius printer.  I'm unable to connect via COM to manually control the printer.  I can connect fine and using CURA I can manually move the printer, but using Repetier I can not connect.  I get "1 Command Waiting" in the bottom right corner.  Here is my log
07:32:46.536 : OpenGL renderer:GeForce GTX 1660 SUPER/PCIe/SSE2
07:32:46.536 : Using fast VBOs for rendering is possible
07:32:51.135 : No start signal detected - forcing start
07:32:51.157 : N1 M110*34
07:32:51.157 : N2 M115*36
07:32:51.157 : N3 M105*36
07:32:51.157 : N4 M114*35
07:32:51.157 : N5 M111 S6*98
07:32:51.157 : N6 T0*60
07:32:51.157 : N7 M80*28
07:32:54.221 : N8 M105*47
07:32:57.262 : N9 M105*46
07:33:00.342 : N10 M105*22
07:34:03.357 : Communication timeout - reset send buffer block
07:34:03.357 : N11 M105*23
07:34:03.359 : N12 G1 Z10 F36000*51
07:34:04.280 : N13 M105*21
07:34:06.446 : zO6?v?B?J?YM&pPY?f?J?B?%?Q-xP)??qE?6??-"E0?}E?6??-??E0?????????????????????????????J?A?_R?A?
I'm assuming the garbage in the last line is the problem.  I tried all the COM ports and get the same thing.
Is there something else I can try?
BR
  • Yes, last line shows that you have set the wrong baud rate. It is normally either 115200 or 250000. So switch to the other and try again until you see no garbage but useful responses.
