Problems differentiating printers.
I have 4 printers of the same model and if I disconnect any and the system reboots the printers connect to different profiles. Even printers connect through a usb hub.
There are 2 parameters in Marlin to identify printers "Custom Machine Name" and "Machine UUID".
Could we incorporate them when connecting each profile to each machine?
https://marlinfw.org/docs/configuration/configuration.html#custom-machine-name
Especially thinking about the future since you have said that you plan to incorporate a filament management system. Besides, if the printer changes profile, the extruded filament and usage time count is lost, which is useful when it comes to knowing when to perform maintenance.
  • We can only detect by serial. If you are using a linux system use the path of connection (port connected) as serial by selecting it over /dev/serial/by-path/...   - these are always the same for same port and link to the real names which depend on detection order.
