Unknown command: -p
edited September 2020 in CuraEngine
Hi all,
This thread started under Repetier Host, but I think the issue lies with CuraEngine...
I am trying to get CuraEngine running on a Raspberry Pi 2.  I compiled and installed it in CuraEngine under plugins in Repetier.
Repetier is calling CuraEngine like this (and I have tried it from the command line and get the same results):
/home/pi/RepetierHost/plugins/CuraEngine/CuraEngine -p -v -c "/home/pi/.local/share/RepetierHost/cura.ini" -s posx=0 -s posy=0 -o "/home/pi/.local/share/RepetierHost/composition.gcode" "/home/pi/.local/share/RepetierHost/composition0.stl"
I get the following error:
[ERROR] Unknown command: -p
[ERROR] Command called:
[ERROR] /home/pi/RepetierHost/plugins/CuraEngine/CuraEngine [ERROR] -p [ERROR] -v [ERROR] -c [ERROR] /home/pi/.local/share/RepetierHost/cura.ini [ERROR] -s [ERROR] posx=0 [ERROR] -s [ERROR] posy=0 [ERROR] -o [ERROR] /home/pi/.local/share/RepetierHost/composition.gcode [ERROR] /home/pi/.local/share/RepetierHost/composition0.stl [ERROR]
and then it goes into the usage
Any suggestions would be most welcome!
  • What version of CuraEngine are you using. The one bundled with host that works as expected is
    08:33:57.766 : <CuraEngine> Cura_SteamEngine version 15.01
    Which is the latest with that kind of configuration. Later versions are 100% incompatible.
  • edited September 2020
    I am unable to run CuraEngine --version or -v but the ChangeLog.md says:
    Changelog CuraEngine
    - Feature: infill_wipe_dist. Add a travel move after an infill line in order to let it stick better to the walls.
    - Feature: Draft Protection Screen. A shell similar to the ooze shield providing protection from gusts of wind and acting similar to a heated chamber
    Release 15.06.01
    Here is the output from ./CuraEngine -h (Note that -h is listed as a valid parameter):
    Cura_SteamEngine version master
    Copyright (C) 2020 Ultimaker
    This program is free software: you can redistribute it and/or modify
    it under the terms of the GNU Affero General Public License as published by
    This program is distributed in the hope that it will be useful,
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU Affero General Public License for more details.
    You should have received a copy of the GNU Affero General Public License
    along with this program.  If not, see <http://www.gnu.org/licenses/>.
    [ERROR] Unknown command: -h
    [ERROR] ./CuraEngine [ERROR] -h [ERROR]
    Can anyone tell me where to find CuraEngine 15.01?
  • I found that Release 4.5 from here:
    https://github.com/Ultimaker/CuraEngine/releases/tag/4.5.0
    is CuraEngine 15.0.6.1
  • I now have 15.0.6.1 installed in pluigins, but I am getting this error:
    pi@repetier:~/CuraEngine-4.5.0/build $ ./CuraEngine -p -v -c "/home/pi/.local/share/RepetierHost/cura.ini" -s posx=0 -s posy=0 -o "/home/pi/.local/share/RepetierHost/composition.gcode" "/home/pi/.local/share/RepetierHost/composition0.stl"
    Copyright (C) 2019 Ultimaker
    [ERROR] ./CuraEngine [ERROR] -p [ERROR] -v [ERROR] -c [ERROR] /home/pi/.local/share/RepetierHost/cura.ini [ERROR] -s [ERROR] posx=0 [ERROR] -s [ERROR] posy=0 [ERROR] -o [ERROR] /home/pi/.local/share/RepetierHost/composition.gcode [ERROR] /home/pi/.local/share/RepetierHost/composition0.stl [ERROR]
  • It still states being too new. This from master branch might be the correct one:
    https://github.com/Ultimaker/CuraEngine/tree/15.06.03
  • OK, now I am having build errors (I guess my other libraries are too new):
    /usr/include/c++/8/bits/stl_uninitialized.h:76:9: note: parameter passing for argument of type ‘std::move_iterator<ClipperLib::IntPoint*>’ changed in GCC 7.1
    [ 17%] Building CXX object CMakeFiles/CuraEngine.dir/src/commandSocket.cpp.o
    /home/pi/CuraEngine-15.06.03/src/commandSocket.cpp: In member function ‘void cura::CommandSocket::connect(const string&, int)’:
    /home/pi/CuraEngine-15.06.03/src/commandSocket.cpp:62:76: error: no matching function for call to ‘Arcus::Socket::registerMessageType(int, const Cura::ObjectList*)’
         d->socket->registerMessageType(1, &Cura::ObjectList::default_instance());
    In file included from /home/pi/CuraEngine-15.06.03/src/commandSocket.cpp:8:
    /usr/local/include/Arcus/Socket.h:73:22: note: candidate: ‘virtual bool Arcus::Socket::registerMessageType(const google::protobuf::Message*)’
             virtual bool registerMessageType(const google::protobuf::Message* message_type);
    /usr/local/include/Arcus/Socket.h:73:22: note:   candidate expects 1 argument, 2 provided
    /home/pi/CuraEngine-15.06.03/src/commandSocket.cpp:63:82: error: no matching function for call to ‘Arcus::Socket::registerMessageType(int, const Cura::SlicedObjectList*)’
         d->socket->registerMessageType(2, &Cura::SlicedObjectList::default_instance());
    /home/pi/CuraEngine-15.06.03/src/commandSocket.cpp:64:74: error: no matching function for call to ‘Arcus::Socket::registerMessageType(int, const Cura::Progress*)’
         d->socket->registerMessageType(3, &Cura::Progress::default_instance());
    /home/pi/CuraEngine-15.06.03/src/commandSocket.cpp:65:76: error: no matching function for call to ‘Arcus::Socket::registerMessageType(int, const Cura::GCodeLayer*)’
         d->socket->registerMessageType(4, &Cura::GCodeLayer::default_instance());
    /home/pi/CuraEngine-15.06.03/src/commandSocket.cpp:66:81: error: no matching function for call to ‘Arcus::Socket::registerMessageType(int, const Cura::ObjectPrintTime*)’
         d->socket->registerMessageType(5, &Cura::ObjectPrintTime::default_instance());
    /home/pi/CuraEngine-15.06.03/src/commandSocket.cpp:67:77: error: no matching function for call to ‘Arcus::Socket::registerMessageType(int, const Cura::SettingList*)’
         d->socket->registerMessageType(6, &Cura::SettingList::default_instance());
    /home/pi/CuraEngine-15.06.03/src/commandSocket.cpp:68:77: error: no matching function for call to ‘Arcus::Socket::registerMessageType(int, const Cura::GCodePrefix*)’
         d->socket->registerMessageType(7, &Cura::GCodePrefix::default_instance());
    /home/pi/CuraEngine-15.06.03/src/commandSocket.cpp:72:22: error: ‘class Arcus::Socket’ has no member named ‘state’
         while(d->socket->state() != Arcus::SocketState::Closed && d->socket->state() != Arcus::SocketState::Error)
    /home/pi/CuraEngine-15.06.03/src/commandSocket.cpp:72:74: error: ‘class Arcus::Socket’ has no member named ‘state’
    /home/pi/CuraEngine-15.06.03/src/commandSocket.cpp:100:24: error: ‘class Arcus::Socket’ has no member named ‘errorString’
             if(!d->socket->errorString().empty()) {
    /home/pi/CuraEngine-15.06.03/src/commandSocket.cpp:101:41: error: ‘class Arcus::Socket’ has no member named ‘errorString’
                 logError("%s\n", d->socket->errorString().data());
    make[2]: *** [CMakeFiles/CuraEngine.dir/build.make:97: CMakeFiles/CuraEngine.dir/src/commandSocket.cpp.o] Error 1
    make[1]: *** [CMakeFiles/Makefile2:73: CMakeFiles/CuraEngine.dir/all] Error 2
    make: *** [Makefile:130: all] Error 2
    I downloaded Arcus from here:
    https://github.com/Ultimaker/libArcus/releases/tag/15.10
    CuraEngine (as suggested by @Repetier) from here:
    protobuf-3.13.0 from here:
    git@github.com:protocolbuffers/protobuf.git
    Here is the log:
    13:28:51.259 : Warning: Seems like we missed a ok, got a wait - continue sending.
    13:29:14.934 : CuraEngine command:/home/pi/RepetierHost/plugins/CuraEngine/CuraEngine -p -v -c "/home/pi/.local/share/RepetierHost/cura.ini" -s posx=0 -s posy=0 -o "/home/pi/.local/share/RepetierHost/composition.gcode" "/home/pi/.local/share/RepetierHost/composition0.stl"
    13:29:14.952 : Preferred name from fence-standoff3 to fence-standoff3
    13:29:15.021 : <CuraEngine> Cura_SteamEngine version DEV
    13:29:15.022 : <CuraEngine> Copyright (C) 2014 David Braam
    13:29:15.023 : <CuraEngine> This program is free software: you can redistribute it and/or modify
    13:29:15.024 : <CuraEngine> it under the terms of the GNU Affero General Public License as published by
    13:29:15.024 : <CuraEngine> the Free Software Foundation, either version 3 of the License, or
    13:29:15.025 : <CuraEngine> (at your option) any later version.
    13:29:15.026 : <CuraEngine> This program is distributed in the hope that it will be useful,
    13:29:15.026 : <CuraEngine> but WITHOUT ANY WARRANTY; without even the implied warranty of
    13:29:15.026 : <CuraEngine> MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    13:29:15.027 : <CuraEngine> GNU Affero General Public License for more details.
    13:29:15.027 : <CuraEngine> You should have received a copy of the GNU Affero General Public License
    13:29:15.028 : <CuraEngine> along with this program.  If not, see <http://www.gnu.org/licenses/>.
    13:29:15.028 : <CuraEngine> Unknown option: c
    13:29:15.028 : <CuraEngine> Warning: setting an unregistered setting posx
    13:29:15.029 : <CuraEngine> Warning: setting an unregistered setting posy
    13:29:15.029 : <CuraEngine> ERROR: Failed to load json file: fdmprinter.json
    13:29:15.029 : <CuraEngine> Loading /home/pi/.local/share/RepetierHost/cura.ini from disk...
    13:29:15.030 : <CuraEngine> Failed to load model: /home/pi/.local/share/RepetierHost/cura.ini
    13:29:15.031 : <CuraEngine> Unregistered setting speed_travel
    13:29:15.031 : <CuraEngine> Unregistered setting machine_end_gcode
    13:29:15.032 : <CuraEngine> maxObjectHeight : 0
    13:29:15.033 : <CuraEngine> Print time: 0
    13:29:15.033 : <CuraEngine> Filament: 0
    13:29:15.304 : Warning: Seems like we missed a ok, got a wait - continue sending.
    Looks like the -c option is not recognized?
    Looks like fdmprinter.json is missing?  Actually, I found it in the CuraEngine source folder.  I copied it to the RepetierHost/plugins/CuraEngine folder but it makes no difference.  From what I have read, Repetier should be passing it as an argument to CuraEngine.
    note that /home/pi/.local/share/RepetierHost/cura.ini exists
    NOTE When I remove the -c parameter and argument, it generates gcode
  • Looks much better but seems still too new. The correct version does not use protobuf - the problems started with switching communication to protobuf. Looking in my message with version it was 15.01 so this
    https://github.com/Ultimaker/CuraEngine/tree/15.01
    which is also not using protobuf.
