Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Server
CreatBot F160 PEEK - Firmware Unknown
cowanhmoore
September 2020
edited September 2020
in
Repetier-Server
I'm trying to add the CreatBot F160 to Repetier Server, but printer does not respond to any of the listed firmware.
Any ideas? Thanks!
Repetier
September 2020
First make sure to use version 0.94.3 - only there you have working autodetect for baud rate and RTS/DTR. Select marlin firmware that is the most likely one that will work. Then go through the wizard and make sure to use the right com port.
Sign In
or
Register
to comment.
