Printing stops and continues to print EXTREMELY slow.
I have encountered this problem 2 times in the same day.
I have 2 CR-10 V3 and 2 Artillery Sidewinder X1 + 1 webcam connected to a Raspberry Pi and a USB hub.
Generally shortly after starting one of the CR-10 V3s it begins to print extremely slowly, as if the commands take a loooong time to arrive.
I leave an example with the date stamp so you can see what I'm talking about.
Send:16:11:52.302: M117 ETA 18:43:43 day 1
Send:16:11:52.302: N1199673 G1 X89.854 Y96.556 E1196.66928
Send:16:11:56.303: N1199674 G1 X90.028 Y96.342 E1196.6968
Send:16:11:56.304: N1199675 G1 X90.2 Y96.152 E1196.72237
Send:16:12:00.306: N1199676 G1 X90.369 Y95.991 E1196.74566
Send:16:12:00.306: N1199677 G1 X90.62 Y95.783 E1196.77819
Send:16:12:04.307: M117 ETE 02:31:51
Send:16:12:04.307: N1199678 G1 X90.743 Y95.695 E1196.79328
Send:16:12:08.308: N1199679 G1 X91.03 Y95.517 E1196.82698
Send:16:12:08.309: N1199680 G1 X91.282 Y95.391 E1196.85509
Send:16:12:12.317: M117 Layer 12/388
Send:16:12:12.317: N1199681 G1 X91.466 Y95.316 E1196.87492
Send:16:12:16.327: N1199682 G1 X91.667 Y95.247 E1196.89612
Send:16:12:16.327: N1199683 G1 X91.863 Y95.192 E1196.91643
Send:16:12:20.334: N1199684 G1 X92.081 Y95.144 E1196.93871
Send:16:12:20.335: N1199685 G1 X92.222 Y95.122 E1196.95295
Send:16:12:24.345: M117 ETA 18:44:13 day 1
  • Looks like your timeout i set to 4 seconds. So after each timeout server sends 2 lines and waits firmware to send "ok" but this seems to not happen. If you enable ack in log you would see the "ok" at least as long as it works. Communication is synced with these responses so they are essential. If firmware stops sending them you get that pattern.
  • edited September 2
    Can it be a problem with the usb cable?
    Can it be fixed in any way when that happens?
  • Do you have the firmware sources and are able to compile and upload them? I have a theory what it is, but that needs to recompile firmware with second serial for the display disabled.
    Printer is new and creality don't release source file for this printer yet.
  • Ok see on https://www.creality.com/download the V3 is missing here.
    When you send M115 what firmware does it show? Did they show marlin 2 as firmware?
