Printer Configuration Wizard: Stuck on step one
in Bug Reports
I type in the printer name and click "Continue with Step 2" and nothing happens for a at least 5 minutes. I click "Continue with Step 2" one or two more times and wait. Then I click Abort. After a couple seconds, its aborted, but then I see that 2 or 3 printers have been added, all with the same name.
If I go to Actions, then Printer Settings, nothing happens. Same with "Go to Printer." I try to go to http://localhost ... /NewPrinter/general (because that is where "Actions" then "Printer Settings" tries to go to, but nothing happens.
Has this happened to anyone else, and how did you fix it?
I also can't get to step 2. The printer does appear in the main page, but you can't open it.
After a reboot you can open the printer...
2015-03-01 22:53:21: error accessing /printer/layeranalysis/Big?id=1&sess=%5EmpVk9%23v%24vMc9k8MQp8FjgtJuS0n2wML: Unknown printer
Thank you,
Errol
