Auto Update from 0.94.1 to 0.94.2 failed
I just updated two Repetier-Server's running 0.94.1 to 0.94.2 via auto-update.
With one server it worked perfectly. The second one does not start up now.
The following message appears on the screen connected to Raspi:
Die Webseite ist nicht errichbar.
127.0.01 hat die Verbindung abgelehnt.
Versuchen Sie folgendes:
- Verbindung prüfen
- Proxy und Firewall prüfen
ERR_CONNECTION_REFUSED
I still can ping the raspi and can also access the raspi via SSH.
Is there anything i can do without reinstallation?
Thanks for you support.
  • Same problem here. Just updated on my production machine...
  • Ich schließe mich dem hier mal an mit meinem Log. Problem wird das selbe sein.
    2020-08-24 06:33:15: Update executable:/usr/local/Repetier-Server/bin/RepetierInstaller
    2020-08-24 06:33:15: Update with config: /usr/local/Repetier-Server/etc/RepetierServer.xml
    2020-08-24 06:33:15: Handling action 'autoupdate' caused error bad_weak_ptr
    2020-08-24 06:33:16: Start logging...
    2020-08-24 06:33:17: Imported external command Shutdown Server
    2020-08-24 06:33:17: Imported external command Reboot Server
    2020-08-24 06:33:17: Webdirectory: /usr/local/Repetier-Server/www/
    2020-08-24 06:33:17: Storage directory: /var/lib/Repetier-Server/
    2020-08-24 06:33:17: Configuration file: /usr/local/Repetier-Server/etc/RepetierServer.xml
    2020-08-24 06:33:17: Directory for temporary files: /tmp/
    2020-08-24 06:33:17: Reading firmware data ...
    2020-08-24 06:33:17: Starting Network ...
    2020-08-24 06:33:17: Active features:4095
    2020-08-24 06:33:17: Reading printer configurations ...
    2020-08-24 06:33:17: Reading printer config /var/lib/Repetier-Server/configs/test4.xml
    2020-08-24 06:33:17: Starting printjob manager thread for test4
    2020-08-24 06:33:17: Reading printer config /var/lib/Repetier-Server/configs/Ender6.xml
    2020-08-24 06:33:17: Starting printjob manager thread for Ender6
    2020-08-24 06:33:17: Starting printer threads ...
    2020-08-24 06:33:17: Starting printer thread for Ender5-UART
    2020-08-24 06:33:17: Starting work dispatcher subsystem ...
    2020-08-24 06:33:17: Starting user database ...
    2020-08-24 06:33:17: Importing projects ...
    2020-08-24 06:33:17: Importing wifi connections from /var/lib/Repetier-Server/database/repetier-network.xml
    2020-08-24 06:33:17: Importing wifi connections from /var/lib/Repetier-Server/database/repetier-network-stored.xml
    2020-08-24 06:33:17: Initializing LUA ...
    2020-08-24 06:33:17: Starting wifi watcher ...
    2020-08-24 06:33:17: Register LUA cloud services
    2020-08-24 06:33:17: add G-Code-Renderer
    2020-08-24 06:33:17: LUA initalization finished.
    2020-08-24 06:33:17: Work dispatcher thread started.
    2020-08-24 06:33:17: Internal work dispatcher thread started.
    2020-08-24 06:33:17: Starting web server ...
    2020-08-24 06:33:17: Webserver started.
    2020-08-24 06:33:18: Websocket opened
    2020-08-24 06:33:18: Client closed connection unexpectedly
    2020-08-24 06:33:18: Connection started: Ender5-UART
    2020-08-24 06:33:18: Reset printer Ender5-UART
    2020-08-24 06:33:24: New SSID Not Connected
    2020-08-24 06:33:39: Websocket opened
    2020-08-24 06:33:47: Handling action 'autoupdate' caused error bad_weak_ptr
    2020-08-24 06:33:47: Update executable:/usr/local/Repetier-Server/bin/RepetierInstaller
    2020-08-24 06:33:47: Update with config: /usr/local/Repetier-Server/etc/RepetierServer.xml
    2020-08-24 06:33:52: Start logging...
    2020-08-24 06:33:52: Imported external command Shutdown Server
    2020-08-24 06:33:52: Imported external command Reboot Server
    2020-08-24 06:33:52: Webdirectory: /usr/local/Repetier-Server/www/
    2020-08-24 06:33:52: Storage directory: /var/lib/Repetier-Server/
    2020-08-24 06:33:52: Configuration file: /usr/local/Repetier-Server/etc/RepetierServer.xml
    2020-08-24 06:33:52: Directory for temporary files: /tmp/
    2020-08-24 06:33:52: Reading firmware data ...
    2020-08-24 06:33:52: Starting Network ...
    2020-08-24 06:33:52: Active features:4095
    2020-08-24 06:33:52: Reading printer configurations ...
    2020-08-24 06:33:52: Reading printer config /var/lib/Repetier-Server/configs/test4.xml
    2020-08-24 06:33:52: Starting printjob manager thread for test4
    2020-08-24 06:33:53: Reading printer config /var/lib/Repetier-Server/configs/Ender6.xml
    2020-08-24 06:33:53: Starting printer threads ...
    2020-08-24 06:33:53: Starting printer thread for Ender5-UART
    2020-08-24 06:33:53: Starting work dispatcher subsystem ...
    2020-08-24 06:33:53: Starting printjob manager thread for Ender6
    2020-08-24 06:33:53: Starting user database ...
    2020-08-24 06:33:53: Importing projects ...
    2020-08-24 06:33:53: Importing wifi connections from /var/lib/Repetier-Server/database/repetier-network.xml
    2020-08-24 06:33:53: Importing wifi connections from /var/lib/Repetier-Server/database/repetier-network-stored.xml
    2020-08-24 06:33:53: Initializing LUA ...
    2020-08-24 06:33:53: Register LUA cloud services
    2020-08-24 06:33:53: add G-Code-Renderer
    2020-08-24 06:33:53: Starting wifi watcher ...
    2020-08-24 06:33:53: LUA initalization finished.
    2020-08-24 06:33:53: Starting web server ...
    2020-08-24 06:33:53: Internal work dispatcher thread started.
    2020-08-24 06:33:53: Work dispatcher thread started.
    2020-08-24 06:33:53: Webserver started.
    2020-08-24 06:33:53: Websocket opened
    2020-08-24 06:33:53: Client closed connection unexpectedly
    2020-08-24 06:33:54: Connection started: Ender5-UART
    2020-08-24 06:33:54: Reset printer Ender5-UART
    2020-08-24 06:33:56: Websocket opened
    2020-08-24 06:34:02: New SSID Not Connected
    2020-08-24 06:34:04: No valid response seen within 10 seconds from printer, restarting connection
    2020-08-24 06:34:04: Port closed for Ender5-UART
    2020-08-24 06:34:04: Connection closed: Ender5-UART
    2020-08-24 06:34:05: Connection started: Ender5-UART
    2020-08-24 06:34:05: Reset printer Ender5-UART
    2020-08-24 06:34:15: No valid response seen within 10 seconds from printer, restarting connection
    2020-08-24 06:34:15: Port closed for Ender5-UART
    2020-08-24 06:34:15: Connection closed: Ender5-UART
    2020-08-24 06:34:16: Connection started: Ender5-UART
    2020-08-24 06:34:16: Reset printer Ender5-UART
    2020-08-24 06:34:18: Execute error response:Failed to query server: Refusing activation, D-Bus is shutting down.
    2020-08-24 06:34:24: Stopping for signal 15
    2020-08-24 06:34:24: Stopping lua runner ...
    2020-08-24 06:34:24: Stopping global cloud ...
    2020-08-24 06:34:24: Stopped wifi watcher.
    2020-08-24 06:34:24: Stopping open threads ...
    2020-08-24 06:34:24: Shutting down web server.
    2020-08-24 06:34:24: Closing server
    2020-08-24 06:34:24: Stopping work dispatcher.
    2020-08-24 06:34:24: Internal Work dispatcher thread stopped.
    2020-08-24 06:34:24: Work dispatcher thread stopped.
    2020-08-24 06:34:24: Waiting for all threads to finish ...
    2020-08-24 06:34:24: Worker threads finsihed.
    2020-08-24 06:34:24: Stopping printer threads.
    2020-08-24 06:34:24: Port closed for Ender5-UART
    2020-08-24 06:34:24: Connection closed: Ender5-UART
    2020-08-24 06:34:24: Printer thread for test4 stopped
    2020-08-24 06:34:24: Printjob manager thread for test4 stopped.
    2020-08-24 06:34:24: Printer thread for Ender6 stopped
    2020-08-24 06:34:24: Printjob manager thread for Ender6 stopped.
    2020-08-24 06:34:24: Closing user database.
    2020-08-24 06:34:24: Server is now down.
  • edited August 2020
    Habe es nun gelöst, in dem ich die Aktuellste Linuxversion (.deb) auf den Pi gezogen habe und manuell per SSH installiert habe. Verbindet sich nun wieder. Drucker verbindet sich allerdings nichtmehr und das Touchdisplay bleibt weiß.
  • When autoupdate does not work you can move to manual installation as described in manual installation section:
    https://www.repetier-server.com/manuals/0.93/index.html
    We already detected that windows is having troubles but linux forked for us so far. Unfortunately it depends on installed version so no solution when 0.94 is having the problem except manuall installation.
    @timoschuett
    Is the gui working normally? What is the server.log content when loading - any errors there. Touchscreen is just a different webpage loaded by chrome running on the pi. For me it sounds like server hangs before the modules are all initialized.
  • @Repetier
    I just got it working, thanks.
    - made a apt-get udpdate and apt-get upgrade which probably killed the display settings
    - Manually installed the new version directly from the pi
    - Display settings adjusted
    - Edited the Printer config from "low to high" to "high to low"
    Now everything should work fine again.
  • I just had to reinstall manually. I did not have to change any printer configurations. All data is still there. Everything works perfectly. Thank's for the competant and quick support.
    You all have a great week!
