Status of print jobs does not show on another machine running repetier host
I'm running v. 2.1.6 in a win10 64bit environment. If i start the job from another machine i cannot see the status, layer info, etc of the running job from another pc. I recall this used to work, perhaps I am wrong? I am including a screenshot of what I see on the other machine. As you can see it is aware of the job, shows the layer # is it on in the log at the bottom as well as ETE. The image is below, it appears I cannot embed it.
https://cfbinc-my.sharepoint.com/:i:/p/dave/EW1QeeDxCrpJr_1UQdpEBxABtCylidsqJIbhT0V94Jbmgg?e=Hi12oU
But host never showed layer for progress only ETA/ETE.
I think you mix that a sit is on same screen. When you select a gcode you see the infos like layer count in server tab. But that is not because it is being printed, but just because you selected the gcode that you then started to print.
Here are working links as to what i'm referencing just in case what I am asking isn't clear.:
Server tab
https://cfbinc-my.sharepoint.com/:i:/p/dave/EcUKxxBqGBlLo5rh9H9I0pMBzwonaw4v6-inmVgylJM2Hg?e=zbqsap
Print Preview tab
https://cfbinc-my.sharepoint.com/:i:/p/dave/EWMq_rgPDr5KuQjiPK8v9CUB2BmxGYSBp0Juz88GPY_9Zg?e=jFamFf
I see you print directly so there are no gcodes in server tab visible. If you instead upload the gcode first it would appear in server tab as file to be selected.
The preview tab shows a preview of the file loaded into the editor of host. Since you do not have one loaded it is empty, so that is also correct. That will also not change since it is the job.
For remote watching the server you should use the official gui - open browser with http://ip:3344 and you will see all you want to see even without host and even on your mobile if it is in same network.
This data is what I refer to as being available and possibly importable into host.
https://cfbinc-my.sharepoint.com/:i:/p/dave/EePMRS3cAkZIueh9GGf-yj4BgiLPH4jILy1B1cIgtW_WqQ?e=iRlZv7
