Prusa slicer configuration does not work
Hello
prusa slicer 2.2.0
repetier host 2.1.6
configuring slicer on Repetier
Manager
Prusa slicer configuration Directory
C:\Users\eazap\AppData\Roaming\Slic3rPE
PrusaSlicer Executable
C:\Program Files\Prusa3D\PrusaSlicer\prusa-slicer.exe
running the configuration for prusaslicer
configuration wizard
I choose my printer and the filaments
In the prusaslicer the dropdown lists for print settings, filaments and Printers are ok (just what I created)
but in the repetier host all printers and printer settings are shown and just the filaments @MMU1, none of the filaments I configured are shown and none of the user filaments I created are shown as well but they can be seen on the directory
C:\Users\eazap\AppData\Roaming\Slic3rPE\filament
Thank you
Eduardo
Next is that Prusa uses massively selection filters to hide a lot of filaments or print profiles depending on selected printer. Host tries to do the same. Please check in your filament to what you limited the selection and if that condition is met in host. If you think it is met, please post the conditions and marker you used in case it is a new syntax.
My config is not so useful. Only my prusa printer and one custom filament at the moment as I installed a new windows recently. But that were the conditions so I always see it. If you modify a existing filament you also get the conditions in your copy.
Can I send some screenshots?
Perhaps you can send some dependencies entries as an example.
So far the dependencies detection worked in repetier-host for me. Just make sure host and slicer use same data directory. But if you open it from host to configure it should use same directory.
I will do that
Thank you
