Filament used tracker
I think it would be handy to have a widget showing the total amount of filament extruded. It could be manually reset when you change the spool. Would be kinda handy for seeing how much filament you have left.
Maybe you could add some options so you can add a new spool and type in its length. Then it could warn you when you're running to the end of your spool.
Could be placed at the top right next to the heated bed temperature. Maybe a little spool icon with something like 200m/400m meaning 200m of 400m total left.
  • For the future a bit more complex solution is planned, so we can also check filament type loaded and wanted by gcode and move filaments around servers and printers.
  • That sounds great looking forward to seeing it. Been very impressed so far.
