Connection Problems Creality CR10-S4
Hi all,
since about 2h I´m trying to setup my CR10S4 in repetier host.
There is somthing like a connection, but the printer does not do anything wenn sending GCode (e.g. G28 or whatever).
Here is a console-output:
Mesg:20:16:08.552: Connection started
Mesg:20:16:08.552: Dtr: false Rts: false
Mesg:20:16:08.566: Dtr: true Rts: true
Recv:20:16:09.643: start
Recv:20:16:09.643: echo: External Reset
Send:20:16:09.643: N0 M110 N0
Send:20:16:09.643: N1 M999 ; In case we did not reset recover from fatal state
Send:20:16:09.643: N1 N1 M110
Send:20:16:09.644: N3 M115 ; Check firmware and capabilities
Send:20:16:09.644: N4 M220 S100 ; set speed multiplier
Send:20:16:09.644: N5 M221 S100 ; set flow multiplier
Send:20:16:09.644: N6 M355 ; get light status
Send:20:16:09.644: N7 G92 E0 ; reset extrude rposition
Send:20:16:09.644: N8 G90 ; absolute coordinates
Send:20:16:09.644: N9 M82 ; absolute E values
Recv:20:16:09.692: Marlin 1.1.6BL_V3.1
Recv:20:16:09.692: echo: Last Updated: 2019-07-26 | Author: CR-10 S4 BLTouch
Recv:20:16:09.692: echo:Compiled: Aug 5 2019
Recv:20:16:09.692: echo: Free Memory: 1337 PlannerBufferBytes: 1232
Recv:20:16:09.692: echo:V41 stored settings retrieved (526 bytes; crc 13656)
Recv:20:16:09.692: echo: G21 ; Units in mm
Recv:20:16:09.692: echo: M149 C ; Units in Celsius
Recv:20:16:09.692: echo:Filament settings: Disabled
Recv:20:16:09.693: echo: M200 D1.75
Recv:20:16:09.693: echo: M200 D0
Recv:20:16:09.693: echo:Steps per unit:
Recv:20:16:09.693: echo: M92 X80.00 Y80.00 Z400.00 E93.00
Recv:20:16:09.693: echo:Maximum feedrates (units/s):
Recv:20:16:09.693: echo: M203 X300.00 Y300.00 Z5.00 E25.00
Recv:20:16:09.734: echo:Maximum Acceleration (units/s2):
Recv:20:16:09.734: echo: M201 X300 Y300 Z100 E1000
Recv:20:16:09.735: echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
Recv:20:16:09.735: echo: M204 P500.00 R500.00 T1000.00
Recv:20:16:09.735: echo:Advanced: S<min_feedrate> T<min_travel_feedrate> B<min_segment_time_ms> X<max_xy_jerk> Z<max_z_jerk> E<max_e_jerk>
Recv:20:16:09.735: echo: M205 S0.00 T0.00 B20000 X10.00 Y10.00 Z0.40 E5.00
Recv:20:16:09.735: echo:Home offset:
Recv:20:16:09.735: echo: M206 X0.00 Y0.00 Z0.00
Recv:20:16:09.735: echo:Auto Bed Leveling:
Recv:20:16:09.735: echo: M420 S0 Z0.00
Recv:20:16:09.735: echo:Material heatup parameters:
Recv:20:16:09.755: echo: M145 S0 H185 B45 F255
Recv:20:16:09.755: M145 S1 H240 B70 F255
Recv:20:16:09.755: echo:PID settings:
Recv:20:16:09.755: echo: M301 P22.57 I1.72 D73.96
Recv:20:16:09.755: echo:Z-Probe Offset (mm):
Recv:20:16:09.755: echo: M851 Z-2.50
Send:20:16:11.298: N10 M205
Recv:20:16:14.570: echo:TF card ok
Recv:20:16:14.609: Init power off infomation.
Recv:20:16:14.609: size:
Recv:20:16:14.609: 585
Recv:20:16:14.609: init valid:
Recv:20:16:14.609: 0 (2)
Recv:20:16:14.609: echo:Unknown command: " "
Recv:20:16:14.609: ok
Recv:20:16:14.609: echo:TF card ok
Recv:20:16:14.610: 585
Recv:20:16:14.610: init valid:
Recv:20:16:14.610: 0 (2)
Recv:20:16:14.625: echo:Unknown command: " "
Recv:20:16:14.625: ok
Send:20:16:14.625: N11 G21 ; units are mm
Send:20:16:14.625: N12 M114 ; check position
Recv:20:16:14.641: echo:Unknown command: " "
Recv:20:16:14.641: ok
Mesg:20:16:45.633: Warning: Communication timeout - resetting communication buffer.
Mesg:20:16:45.633: Connection status: Buffered:93, Manual Commands: 15, Job Commands: 0
Mesg:20:16:45.633: Buffer used:93 Enforced free byte:11 lines stored:11
Send:20:16:45.633: N0 M111 S6 ; debug flags
Send:20:16:45.633: N1 M360 ; get configuration
Send:20:16:45.633: N2 M539 S1
Send:20:16:45.633: @getip
Send:20:16:45.634: N4 M115
Send:20:16:45.634: N5 M27
Send:20:16:45.634: N6 M106 S20
Send:20:16:45.634: N7 M107
Send:20:16:45.634: N9 M360
Send:20:16:45.634: @getip
Send:20:16:45.635: N1 N1 M110
Recv:20:16:45.640: echo:Unknown command: ""
Recv:20:16:45.640: ok
Recv:20:16:45.640: Slow command added:G28
Send:20:16:45.640: N2 G28
Recv:20:16:45.656: Error:Line Number is not Last Line Number+1, Last Line: 0
Recv:20:16:45.656: Resend: 1
Recv:20:16:45.656: ok
Recv:20:16:45.656: Slow command added:G28
Send:20:16:45.656: N3 G28
Printer is running original Creality Marlin 1.1.6BL_V3.1.
Before I´ve tested TH3D - same
I´m not sure what to do now
Anybody any suggestions?
![:( :(](/resources/emoji/frowning.png)
So what I first did not understand is why Ping-Pong option not found in the wizard...
Thx for your help!
Was a little bit strange....
