Cancel Object
Hi. I print objects that overlap at different heights and the solution of ignoring areas does not work for me.
Could we cancel objects based on tags like other softwares do?
If you modified marlin and you know which object has which id and used that postprocessor adding the required marker you could send that command. You can send commands during print so that would not be the problem and since server is not really involved except sending the command you can use that.
Could it cause the head to stop for a moment ruining the other parts?
It is something I must try.
But that gives me a good idea for our planned slicer:-) We could add a list of objects and marker so we can offer that instead for skipping then.
