Adjust Interval for "temp" event send by repetier server
Is there a way to adjust the interval for the "temp" event sent by the server?
It appears that the event is sent periodically and is not based on a temperature change. So is there a way to adjust this interval or something similar?
Background:
I am writing a repetier-server client in C# and would like to collect temperature information among other things.  This works fine for me, but I have noticed that a lot of data sent from the server is exactly the same in a short time and instead of discarding data, I rather would like to adjust the event interval.
Little sidenode:
The repetier server api documentation (https://www.repetier-server.com/manuals/programming/API/index.html) could need an update. :-)
Best regards
M. Bartholet
  • No it is one set every second normally. You can compress it internally if you like but even for unchanged value i need to send that it is same at current time.
