Print objects one at a time.
Prusa slicer allows you to print objects one at a time, which seems to me a sensible way to do things, provided there is room on the bed to avoid collisions.
Can this be done with repetier?
  • You can send such code, but for slicing you need to do it on the slicer directly. From host this is not possible. Also be aware that is a potential dangerous function especially with bigger objects.
  • I vote for this feature to be added to Repetier. I would use this VERY OFTEN. Currently, I have to slice, copy the G-Code, add a new part, slice again, then paste my G-Code. This takes a very long time if have many parts to add.
