how to obtain old versions? 0.92
i got a micromake d1 getting dust in a corner. I uild it up but never programmed nor calibrate and now i lost all the software that comes with the printer.
I'm trying to let it run but seems it runs on repetier 0.92 ... and i cannot download it.
Is there a solution? a "legacy" download site or a more modern firmware for the micromake d1?
thanks
  • 0.92 is still available in our config tool. But also 1.0.4 with many fixes. When you know the required pins and sensor types and board type you can easily make a updated version. Especially if you have the old sources a look into configuration.h reveals all required settings that are hardware dependent.
    I don't have the printer but maybe someone else has already a config from the config tool.
