Setting temperatures does not work for Prusa MK3s
Hi.
After the update, which fixed the cameras - thank you, Now if I try to set the hotend or bed temp manually through the UI. it just does nothing.
Any help please?
Richard
  • Do you mean setting with the knob dial? I found out that it only takes every second change or so. No idea why that started to not work as I did not change that. Looks like some timings have changed and now the block comes before the send data.
    Using preconfigured temperatures in dropdown menu still works (must be predefined in printer settings->extruder). Also of course sending the gcode directly. Just with the know try to change it twice.
    Will be fixed in next update.
