0.60.1 Looks Good
Just did the upgrade to the Raspberry Pi 2 and running a print through it now.
The user interface is starting to be very good now and I can extrude new filament without looking too hard
i had this in my logfile:
63 Y54.095 E3758.39676
> 21:15:30: ok 57507
< 21:15:30: N57514 G1 X26.443 Y55.385 E3758.48136
> 21:15:30: ok 57508
< 21:15:30: N57515 G1 X25.928 Y56.687 E3758.56868
> 21:15:30: ok 57509
< 21:15:30: N57516 G1 X25.354 Y57.923 E3758.65367
> 21:15:30: ok 57510
< 21:15:30: N57517 G1 X24.697 Y59.140 E3758.73992
> 21:15:30: ok 57511
< 21:15:31: N57518 G1 X23.969 Y60.314 E3758.82606
> 21:15:31: ok 57512
< 21:15:31: N57519 G1 X23.955 Y60.336 E3758.82769
> 21:15:31: ok 57513
< 21:15:31: N57520 G1 X23.246 Y60.975 E3758.88721
> 21:15:31: ok 57514
< 21:15:31: N57521 M105
< 21:15:31: N57522 G1 X22.840 Y61.273 E3758.91862
> 21:15:31: ok 57515
< 21:15:31: N57523 G1 X22.415 Y61.544 E3758.95005
> 21:15:31: ok 57516
< 21:15:31: N57524 G1 X21.967 Y61.790 E3758.98193
> 21:15:31: ok 57517
< 21:15:31: N57525 G1 X21.033 Y62.185 E3759.04517
> 21:15:31: ok 57518
< 21:15:31: N57526 G1 X20.045 Y62.454 E3759.10903
> 21:15:31: ok 57519
< 21:15:31: N57527 G1 X19.068 Y62.584 E3759.17049
> 21:15:31: ok 57520
> 21:15:32: ok 57521
< 21:15:32: N57528 M105
> 21:16:04: Warning: Communication timeout - resetting communication buffer.
< 21:16:04: N57529 M105
< 21:16:04: N57530 M105
< 21:16:04: N57531 G1 X18.525 Y62.603 E3759.20438
< 21:16:04: N57532 G1 X17.861 Y62.602 E3759.24578
< 21:16:05: N57533 G1 X0.942 Y62.603 E3760.30090
< 21:16:05: N57534 G1 X0.431 Y62.602 E3760.33277
< 21:16:05: N57535 G1 X-17.315 Y62.603 E3761.43946
< 21:16:05: N57536 G1 X-17.859 Y62.602 E3761.47338
> 21:16:36: Warning: Communication timeout - resetting communication buffer.
< 21:16:36: N57537 M105
< 21:16:36: N57538 M105
< 21:16:36: N57539 G1 X-18.525 Y62.602 E3761.51492
< 21:16:37: N57540 G1 X-19.068 Y62.584 E3761.54880
< 21:16:37: N57541 G1 X-20.045 Y62.454 E3761.61026
< 21:16:37: N57542 G1 X-20.565 Y62.330 E3761.64360
< 21:16:37: N57543 G1 X-21.517 Y61.998 E3761.70648
< 21:16:37: N57544 G1 X-21.967 Y61.790 E3761.73739
Linux raspberrypi 3.18.11-v7+ #781 SMP PREEMPT Tue Apr 21 18:07:59 BST 2015 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Thu May 28 20:23:46 2015 from roberts-macbook-air.local
pi@raspberrypi
Had update and upgrade installed 2 days ago.
Printer is seemecnc rostock max v2 with a standard rambo 1.3 and seemecnc repetier .091 software.
Anymore, just ask
I have built a new raspian wheezy for the Pi with update and upgrade done and I have installed your file as above, I will give it a workout tomorrow and see how it goes, might plug the printer in via a powered hub too just to be doubly safe.
processor : 0
model name : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 2.28
Features : half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2708
Revision : 000f
Serial : 00000000d8973516
firmware i use 0.92.3
i downgraded to serv er 60.0 and will try again. the one that stalled was my first print with the latest version
I can run a lead direct to the router but it would be a last resort and only for testing, see how the other dongle goes first.
The rpi2 is stock standard and just the bare raspian with only the repetier server at present, it has only just been loaded with everything.
Just caught a wait so it looks like the dongle is no good either, get the wire out and here comes a direct connection to the hub.
