Ender 3 pro
I have a stock Ender 3 pro and when I plug in my printer to my RaspberryPi running Repeiter server. It connects I think but nothing is controllable. Is there something I need to do to get it to work and control? Everything is stock on the printer.
  • Does connection symbol get green?
    What do you see in console if you disable all filters?
    It is important to have set the right firmware type. Also make sure you have selected the correct serial port - if you only have one printer it is the one starting with /dev/serial/by-id - the virtual ones are not your printer.
