Anet A8 Firmware EEPPROM Configuration
Hi I am having issues reading the EEPPROM Configuration from my Anet A8, the printer is connected and talking and can control and send data to printer, but unable to get any data back regarding EEPROM?
  • Can happen when M115 does not return a known firmware name for marlin. In next release I want to use the set firmware type for this.
    In the meanwhile you can use repetier-server where this is already the case. Or you send manually
    M503
    and see the values and send the correct command to change the one you want to change.
