Loading a .ini file
Hi
I've just resurrected an abandoned Geeetech i3 Pro B to go with my Ender 5. I'm having problems with the settings. When I start a print, it lifts the nozzle, tries to move, makes a load of grinding noises and then prints the model right on the front edge of the bed instead of the middle with the nozzle still about 5mm from the bed. I've set the bed height and saved it.
I'm assuming it's something to do with the settings and have downloaded a .ini file that is supposed to have the correct profile for this printer. But I can't work out how to load it.
I'm running Repetier-Host-Mac.
If anyone could point me in the right direction I'd be grateful.
Cheers
Andy
Cheers
Andy
If you have ini files for all three you can copy it to the slic3r storage. it is in home/Library/Application Support/Slic3r if I remember right,
