Printproblem Repetier Server dont recives the Temperatures
I have from 2 Weeks on the problem that Repetier Server miss the temperatures.
Installation:
Windows PC -> Connected with USB Cable (2m) to the Printer (ANET A8 Firmware SKYNET 2.3.2)
Attached 1 webcam set up with Yawcam
1 Run out sensor (raspberry pi)
Problems until now:
Start of the PC (automatic start of the service from Repetier Server and Yawcam) - Printer is running on start (Printer temp: HB - 60, HE 200 (displayed on the screen of the printer) - Repetier server temp (HB - 0, HE 200). Restart o the printer → Same problem again, restart of the PC and the temperature was found now.
So the next test first start the PC then the Printer: Same problem as before only way to solve is to restart the windows PC (or the service) again.
Until now it was not a big problem, because i know the problem and how to solve.
But from today on I have become a bigger issue because this problem occurs also if i make a longer print (today print of 6 hours) one of the other moment the HB temperature was put to 0 on the Repetier server (Print stop). On the printer was again 60. The only way to solve was to restart the Service on the PC.
I don't know before 1 month all is working fine and until now nothing changed on printer and PC side.
Has you an idea what I can check or how i can solve this problem?
If you need more information let me know.
Thank You
withewolf
Server extracts temperature from temperature response which ideally contains current AND set temperature. That is default on most firmwares. Looks like
T: 198 /200 @:88 B: 59 /60 @B:20
os similar. If the firmware has changed sending it differently or uses same names for other values this can confuse server. But that should be visible in the log. Use dropbox or similar for providing the log.
