Heat extruder won’t reach default temperature
I originally set my extruder default temperature at 215 but it doesn’t heat up past 200 so I have adjusted this to 200 now but every time I want to start a print, it still says the default heat is 215. How do I sort this out.
I have uninstalled the program and reinstated but its the same.
Please help, I want to print ????
You should check in temperature view how high the output is. When you say 220 and it is all 100% and does not go over 200 that heater can not go higher. If it is not 100% then firmware is limiting it.
