MacOS 10.14.6 - Inst. MAC Version of Rep-Server - USBconnect to printer not working with other slicr
I did as above, installed the MAC version of Rep-Server as a test version. Then move over to PI3+ and forgot abt the MAC Vesion Anyhow, therafter, when I wanted to connect S3D or Cura or Pronterface with the printer (CR10SProV2), USB did not allow connection and reported CRC error. Some communication with pronterface was still possible. But not with S3D or Cura. Deleted rep.server from launchd service via command line (sudo launchctl unload /Library/LaunchDaemons/com.repetier-server.RepetierServer.plist) and removed the plist file (sudo rm /Library/LaunchDaemons/com.repetier-server.RepetierServer.plist) and thereafter deleted all other remains of rep-server (found them via EasyFind). Restart and everything fine again. This deep involvement of Rep--Server is really annoying. regards Manfred
  • If you have configured a printer server will autoconnect to it just like other softwares do like S3D. YOu can stop this any time by selecting the "Disable" menu entry in the printer entry. After that server will still run as it is a background server until you stop it with unload.
    For full desinatllation use
    sudo /usr/local/Repetier-Server/bin/fulluninstall.sh
