Extruder 2 does not appear on the slicer tab for Slic3r engine
Hi, I can't tell if this is a bug or I'm missing something. When I use the Slic3r engine and have configured the slic3r printer settings that there are 2 extruders which both show up in the Slic3r settings, the 2nd extruder does not show up in the Repetier panel. The sliced G-Code seems to still be created correctly and i can assign the object to use the 2nd extruder, but I cannot see or select it from the Slicer tab.
Snapshot of Repetier Host and Slic3f screens
I should note that I am using a dual extruder, single hot end nozzle setup.
