windows 7 64 bit crashing
Hi there
I am running a Prusa I3 with Arduino mega / Ramps v1.4 with Sprinter firmware on Windows 7 with I7 computer. I have no issues I hit print and as soon as the extruder reaches temp and the print head moves to the center of the board, I get Repetier Host has failed message and windows never gets back either. what can I do to correct this.
Nutt
Nutt
It is still crashing as before and the error message is "Repetier host has stopped working" how do i solve this?
I am having the same problem. My Repetier host worked for at least 6 months with no problem, and yesterday It crashes all the times on startup. I am suspecting that after the latest windows 7 updates, this problem start to occur.
I have followed all the possible tips to solve the problem, but still no success:
- Uninstall repetier host, using a tool clean register for all entries of "repetier", also manually remove all data folders from repetier
- Install the fonts
- Re-Install the video drivers
- Try the oldest versions of repetier
I have submit a technical support message.
Here it is the message that I get from windows after software crashes:
Problem signature:
Problem Event Name: APPCRASH
Application Name: RepetierHost.exe
Application Version: 1.0.0.0
Application Timestamp: 548b0e64
Fault Module Name: clr.dll
Fault Module Version: 4.0.30319.34209
Fault Module Timestamp: 5348a1ef
Exception Code: c0000005
Exception Offset: 0000000000002cdf
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1053
Additional Information 1: fe92
Additional Information 2: fe922ed72a83d91dcf566a728f0633a0
Additional Information 3: 3320
Additional Information 4: 332034037423b1d3ce2535d4264150ff
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
http://forum.repetier.com/discussion/769/solved-windows-7-64-bit-crashing
