Problems with extcommands.xml under Windows8.1
Hello there,
Like discribed in the manual I created the extcommands.xml file and stored it in C:\ProgramData\Repetier-Server\database
After restarting the repetier server service the new commands appeared in the menu - ok until here. The problem is that no of my created commands are working an in the server.log it says the following:
2015-05-14 16:07:19: Connection started:RF1000
2015-05-14 16:07:19: Reset printer RF1000
2015-05-14 16:07:33: Opening websocket 2
2015-05-14 16:07:33: New session: 1ofOdfHG3@OFPaD@Z8xuYx*fZ@B8wH0E
2015-05-14 16:07:46: Starting external command c:Windowsnotepad.exe with 0 parameters.
2015-05-14 16:07:46: Handling action runExternalCommand caused error System exception
My extcommands.xml looks like:
<config>
If you want to run external commands, enter them in this configuration with
full path. You will see them in the main menu. Copy this file into the
<storage>/database directory.
Security consideration: The reason there is no online editor for this is simply
security. The commands you enter here are executed with the privileges of the
daemon running the server. If you would allow online configuration, a hacker could
simply add any command he needs to hack your system.
<command>
<name>Server herunterfahren</name>
<execute>c:\Windows\System32\shutdown.exe /s /m \\localhost /t 3200</execute>
<confirm>Server wirklich herunterfahren?</confirm>
</command>
<command>
<name>Herunterfahren abbrechen</name>
<execute>c:\Windows\System32\shutdown.exe /a</execute>
</command>
<command>
<name>Test</name>
<execute>c:\Windows\notepad.exe</execute>
</command>
G-code files can contain
@execute cmd param1 param2
commands. To prevent external users from executing unwanted or dangerous commands,
only commands defined here are allowed to execute. More over, only the shortcuts
defined here are to be used as cmd in @execute. Prevent parameter where ever possible.
<execute name="curl" allowParams="true">c:\Windows\curl.exe</execute>
</config>
So it looks like the repetier server is ignoring the backslash's !??
It tried to run the server with the logged in user instead the system user but nothing changed.
So I am out of ideas to create a workarround :-)
Happy for new suggestions...
<config>
<command>
</command>
<command>
</command>
<command>
<name>Test</name>
</command>
</config>
The service is running with my logged in user account (I changed it in the service preferences - like I posted in my first comment).
