How to change default port of Repetier-Server 0.51.1
Hi All,
I am very pleased with the Repetier-Server 0.51.1 so far. Everything is running really good on RaspberryPi B+. I want to change the default port from 3344 to 80. I don't have any other web server running on the Pi and 80 is more convenient for me. I found /usr/local/Repetier-Server/etc/RepetierServer.xml configuration file, but when I change the port setting in the file, the server refuses to start. It seems to work only with 3344, I tried different ports and it's not working with any of them. I am, obviously, missing something out, but I don't know what. If someone have idea what is wrong please share it
Thank you in advance!
Tsvetan
