Raspberry PI4 and alfawise U30 PRO
Hi i have this problem...printer work and stop continually any Idea?
21:23:36.330: start
21:23:36.330: echo:Marlin 1.1.9
21:23:36.335: echo: Last Updated: 2018-08-01 | Author: (none, default config)
21:23:36.337: echo:Compiled: Jun 11 2019
21:23:36.343: echo: Free Memory: 1686 PlannerBufferBytes: 1232
21:23:36.346: echo:EEPROM version mismatch (EEPROM=? Marlin=V55)
21:23:36.349: echo:Hardcoded Default Settings Loaded
21:23:37.215: echo:SD card ok
21:23:56.252: FIRMWARE_NAME:Marlin 1.1.9 (Github) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:3D Printer EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
21:23:56.252: Cap:SERIAL_XON_XOFF:0
21:23:56.252: Cap:EEPROM:1
21:23:56.252: Cap:VOLUMETRIC:1
21:23:56.252: Cap:AUTOREPORT_TEMP:1
21:23:56.252: Cap:PROGRESS:0
21:23:56.252: Cap:PRINT_JOB:1
21:23:56.252: Cap:AUTOLEVEL:0
21:23:56.252: Cap:Z_PROBE:0
21:23:56.252: Cap:LEVELING_DATA:0
21:23:56.252: Cap:BUILD_PERCENT:0
21:23:56.252: Cap:SOFTWARE_POWER:0
21:23:56.252: Cap:TOGGLE_LIGHTS:0
21:23:56.252: Cap:CASE_LIGHT_BRIGHTNESS:0
21:23:56.252: Cap:EMERGENCY_PARSER:1
21:23:56.252: Cap:AUTOREPORT_SD_STATUS:0
21:23:56.252: Cap:THERMAL_PROTECTION:1
21:23:56.252: X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:0
21:23:56.253: Warning: Communication timeout - resetting communication buffer.
21:23:56.253: Connection status: Buffered:10, Manual Commands: 4, Job Commands: 0
21:23:56.253: Buffer used:10 Enforced free byte:0 lines stored:1
21:43:03.294: Warning: Communication timeout - resetting communication buffer.
21:43:03.295: Connection status: Buffered:0, Manual Commands: 0, Job Commands: 0
21:43:03.295: Buffer used:0 Enforced free byte:0 lines stored:0
What normally is the problem is that communication errors happen and not all returned "ok" messages are received like that, so server does not know that the command is finished.
Unfortunately the firmware seems to have all features disabled that would help fixing such errors or are not visible in log due to hiding some communication. When firmware has ok with line numbers, wait and busy protocol enabled server can quite quickly detect a missed ok.
dmesg
you will see if you have undervoltage from time to time. Also it not always causes a disconnect it seems still to cause problems from time to time. And without firmware side ways to detect this the last resort is timeout. What you need is a power supply best with 5.1 or 5.2v. But the fact that linux does not disconnect usb is already good. With bigger problems linux will disable usb for a short time causing a full abort.
