Massportal Connection to Repetier Host
Hi everyone
I am desperately trying to connect my printer to Repetier host.
- Printer: Massportal Pharaoh XD20
- PC: Windows 10
- Printing Software: Repetier Host v2.1.6
Repetier Host Printer Settings:
- Serial connection COM1 (USB Connection)
- Baudrate 115200
- Transferprotocoll ASCII
- RTS: High
- DTR: Low
- Receiver Cage 127
- Com Timeout: 40
With these settings, the Repetier host connects to the printer but would still not allow me to operate it.
Repetier host gives the following Log messages:
09:38:31.506 : Welcome!
09:38:31.506 : start
09:38:31.553 : Resend:1
09:38:31.616 : Resend:1
09:39:11.589 : Communication timeout - reset send buffer block
Any input welcome.
10:42:14.092 : OpenGL extensions:GL_AMD_multi_draw_indirect GL_AMD_seamless_cubemap_per_texture GL_AMD_vertex_shader_viewport_index GL_AMD_vertex_shader_layer GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_bindless_texture GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_compute_shader GL_ARB_compute_variable_group_size GL_ARB_conditional_render_inverted GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_2_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_fragment_shader_interlock GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gl_spirv GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_gpu_shader_int64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_polygon_offset_clamp GL_ARB_post_depth_coverage GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_locations GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_ballot GL_ARB_shader_bit_encoding GL_ARB_shader_clock GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shader_viewport_layer_array GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_sparse_buffer GL_ARB_sparse_texture GL_ARB_sparse_texture2 GL_ARB_sparse_texture_clamp GL_ARB_spirv_extensions GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_filter_anisotropic GL_ARB_texture_filter_minmax GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset_clamp GL_EXT_post_depth_coverage GL_EXT_provoking_vertex GL_EXT_raster_multisample GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_image_load_formatted GL_EXT_shader_image_load_store GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_sparse_texture2 GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_filter_minmax GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_R8 GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_EXT_window_rectangles GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_context_flush_control GL_KHR_debug GL_EXT_memory_object GL_EXT_memory_object_win32 GL_EXT_win32_keyed_mutex GL_KHR_parallel_shader_compile GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_EXT_semaphore GL_EXT_semaphore_win32 GL_KTX_buffer_region GL_NV_alpha_to_coverage_dither_control GL_NV_bindless_multi_draw_indirect GL_NV_bindless_multi_draw_indirect_count GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent GL_NV_blend_minmax_factor GL_NV_blend_square GL_NV_command_list GL_NV_compute_program5 GL_NV_conditional_render GL_NV_conservative_raster GL_NV_conservative_raster_dilate GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_draw_texture GL_NV_draw_vulkan_image GL_NV_ES1_1_compatibility GL_NV_ES3_1_compatibility GL_NV_explicit_multisample GL_NV_feature_query GL_NV_fence GL_NV_fill_rectangle GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_coverage_to_color GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_fragment_shader_interlock GL_NV_framebuffer_mixed_samples GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_geometry_shader_passthrough GL_NV_gpu_program4 GL_NV_internalformat_sample_query GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program5_mem_extended GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float GL_NV_light_max_exponent GL_NV_memory_attachment GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_path_rendering_shared_edge GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_query_resource GL_NV_query_resource_tag GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_sample_locations GL_NV_sample_mask_override_coverage GL_NV_shader_atomic_counters GL_NV_shader_atomic_float GL_NV_shader_atomic_fp16_vector GL_NV_shader_atomic_int64 GL_NV_shader_buffer_load GL_NV_shader_storage_buffer_object GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_rectangle_compressed GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_uniform_buffer_unified_memory GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NV_viewport_array2 GL_NV_viewport_swizzle GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_NVX_multigpu_info GL_NVX_nvenc_interop GL_NV_shader_thread_group GL_NV_shader_thread_shuffle GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_OVR_multiview GL_OVR_multiview2 GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
10:42:14.092 : OpenGL renderer:GeForce GTX 970/PCIe/SSE2
10:42:14.092 : Using fast VBOs for rendering is possible
10:42:20.096 : wait
10:42:21.065 : wait
10:42:21.836 : No start signal detected - forcing start
10:42:21.873 : N1 M110*34
10:42:21.873 : N2 M115*36
10:42:21.873 : N3 M105*36
10:42:21.873 : N4 M114*35
10:42:21.873 : N5 M111 S6*98
10:42:21.873 : N6 T0*60
10:42:21.873 : N7 M20*22
10:42:21.873 : N8 M80*19
10:42:22.074 : wait
10:42:22.137 : T:15.87 /0 B:13.89 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:23.077 : wait
10:42:23.146 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:24.081 : wait
10:42:24.143 : T:15.87 /0 B:13.89 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:24.930 : N9 M105*46
10:42:25.084 : wait
10:42:25.146 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:26.087 : wait
10:42:26.141 : T:15.75 /0 B:14.10 /0 B@:0 @:0 T0:15.75 /0 @0:0 T1:15.75 /0 @1:0
10:42:27.090 : wait
10:42:27.153 : T:15.75 /0 B:13.89 /0 B@:0 @:0 T0:15.75 /0 @0:0 T1:15.75 /0 @1:0
10:42:28.040 : N10 M105*22
10:42:28.040 : ok 0
10:42:28.056 : Unknown command:N73 I0.00
10:42:28.156 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:29.043 : wait
10:42:29.159 : T:15.75 /0 B:13.89 /0 B@:0 @:0 T0:15.75 /0 @0:0 T1:15.75 /0 @1:0
10:42:30.046 : wait
10:42:30.162 : T:15.75 /0 B:13.89 /0 B@:0 @:0 T0:15.75 /0 @0:0 T1:15.75 /0 @1:0
10:42:30.216 : N11 G28*35
10:42:31.049 : wait
10:42:31.103 : N12 M105*20
10:42:31.150 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:32.060 : wait
10:42:32.161 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:33.067 : wait
10:42:33.161 : T:15.75 /0 B:13.89 /0 B@:0 @:0 T0:15.75 /0 @0:0 T1:15.75 /0 @1:0
10:42:34.067 : wait
10:42:34.161 : N13 M105*21
10:42:34.161 : T:15.75 /0 B:13.89 /0 B@:0 @:0 T0:15.75 /0 @0:0 T1:15.75 /0 @1:0
10:42:34.192 : ok 0
10:42:34.208 : Unknown command:N81 I0.00
10:42:35.159 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:35.191 : wait
10:42:36.175 : T:15.75 /0 B:13.89 /0 B@:0 @:0 T0:15.75 /0 @0:0 T1:15.75 /0 @1:0
10:42:36.206 : wait
10:42:37.173 : T:15.75 /0 B:13.89 /0 B@:0 @:0 T0:15.75 /0 @0:0 T1:15.75 /0 @1:0
10:42:37.204 : wait
10:42:37.236 : N14 M105*18
10:42:37.876 : N15 G1 Y120 F4800*60
10:42:38.177 : T:15.87 /0 B:13.89 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:38.208 : wait
10:42:38.958 : N16 G1 Y110 F4800*60
10:42:39.177 : T:15.75 /0 B:13.89 /0 B@:0 @:0 T0:15.75 /0 @0:0 T1:15.75 /0 @1:0
10:42:39.208 : wait
10:42:40.174 : T:15.75 /0 B:13.89 /0 B@:0 @:0 T0:15.75 /0 @0:0 T1:15.75 /0 @1:0
10:42:40.205 : wait
10:42:40.299 : N17 M105*17
10:42:41.189 : T:15.75 /0 B:14.10 /0 B@:0 @:0 T0:15.75 /0 @0:0 T1:15.75 /0 @1:0
10:42:41.205 : wait
10:42:42.182 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:42.213 : wait
10:42:43.182 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:43.213 : wait
10:42:44.190 : T:15.75 /0 B:14.10 /0 B@:0 @:0 T0:15.75 /0 @0:0 T1:15.75 /0 @1:0
10:42:44.221 : wait
10:42:45.193 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:45.224 : wait
10:42:46.209 : T:15.87 /0 B:13.89 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:46.209 : wait
10:42:47.209 : T:15.75 /0 B:13.89 /0 B@:0 @:0 T0:15.75 /0 @0:0 T1:15.75 /0 @1:0
10:42:47.225 : wait
10:42:48.209 : T:15.75 /0 B:14.10 /0 B@:0 @:0 T0:15.75 /0 @0:0 T1:15.75 /0 @1:0
10:42:48.240 : wait
10:42:49.209 : T:15.87 /0 B:13.89 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:49.240 : wait
10:42:50.207 : T:15.75 /0 B:14.10 /0 B@:0 @:0 T0:15.75 /0 @0:0 T1:15.75 /0 @1:0
10:42:50.239 : wait
10:42:51.207 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:51.239 : wait
10:42:52.208 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:52.239 : wait
10:42:53.213 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:53.245 : wait
10:42:54.229 : T:15.87 /0 B:13.89 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:54.245 : wait
10:42:55.221 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:55.252 : wait
10:42:56.224 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:56.255 : wait
10:42:57.224 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:57.255 : wait
10:42:58.224 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:58.255 : wait
10:42:59.224 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:42:59.255 : wait
10:43:00.223 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:00.255 : wait
10:43:01.239 : T:15.75 /0 B:13.89 /0 B@:0 @:0 T0:15.75 /0 @0:0 T1:15.75 /0 @1:0
10:43:01.272 : wait
10:43:02.241 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:02.272 : wait
10:43:03.241 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:03.288 : wait
10:43:04.241 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:04.272 : wait
10:43:05.243 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:05.290 : wait
10:43:06.243 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:06.290 : wait
10:43:07.243 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:07.290 : wait
10:43:08.243 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:08.290 : wait
10:43:09.248 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:09.295 : wait
10:43:10.253 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:10.300 : wait
10:43:11.260 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:11.307 : wait
10:43:12.260 : T:15.87 /0 B:13.89 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:12.307 : wait
10:43:13.260 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:13.307 : wait
10:43:14.254 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:14.301 : wait
10:43:15.267 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:15.314 : wait
10:43:16.262 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:43:16.309 : wait
10:43:17.277 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:17.324 : wait
10:43:18.277 : T:15.87 /0 B:13.89 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:18.324 : wait
10:43:19.278 : T:15.99 /0 B:13.89 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:43:19.325 : wait
10:43:20.283 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:20.330 : wait
10:43:21.279 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:21.326 : wait
10:43:22.279 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:22.326 : wait
10:43:23.285 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:43:23.332 : wait
10:43:24.285 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:24.332 : wait
10:43:25.285 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:25.332 : wait
10:43:26.296 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:26.343 : wait
10:43:27.296 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:27.343 : wait
10:43:28.296 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:43:28.343 : wait
10:43:29.303 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:29.350 : wait
10:43:30.300 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:43:30.346 : wait
10:43:31.313 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:31.359 : wait
10:43:32.313 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:32.344 : wait
10:43:33.313 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:33.360 : wait
10:43:34.313 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:43:34.344 : wait
10:43:35.314 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:35.346 : wait
10:43:36.329 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:43:36.360 : wait
10:43:37.329 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:43:37.360 : wait
10:43:38.332 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:38.364 : wait
10:43:39.332 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:39.364 : wait
10:43:40.330 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:43:40.362 : wait
10:43:41.346 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:41.377 : wait
10:43:42.346 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:42.378 : wait
10:43:43.346 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:43:43.378 : wait
10:43:44.347 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:43:44.378 : wait
10:43:45.346 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:45.377 : wait
10:43:46.347 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:46.378 : wait
10:43:47.363 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:43:47.394 : wait
10:43:48.410 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:48.410 : wait
10:43:49.363 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:49.399 : wait
10:43:50.363 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:43:50.394 : wait
10:43:51.363 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:43:51.394 : wait
10:43:52.379 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:43:52.410 : wait
10:43:53.369 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:53.400 : wait
10:43:54.369 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:43:54.411 : wait
10:43:55.380 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:43:55.411 : wait
10:43:56.380 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:43:56.411 : wait
10:43:57.380 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:43:57.411 : wait
10:43:58.380 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:43:58.411 : wait
10:43:59.380 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:43:59.424 : wait
10:44:00.395 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:44:00.426 : wait
10:44:01.394 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:44:01.425 : wait
10:44:02.397 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:44:02.428 : wait
10:44:03.400 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:44:03.431 : wait
10:44:04.403 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:44:04.440 : wait
10:44:05.406 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:44:05.437 : wait
10:44:06.409 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:44:06.441 : wait
10:44:07.412 : T:15.99 /0 B:14.30 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:44:07.444 : wait
10:44:08.415 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:44:08.446 : wait
10:44:09.418 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:44:09.440 : wait
10:44:10.421 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:44:10.452 : wait
10:44:11.423 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:44:11.454 : wait
10:44:12.423 : T:15.99 /0 B:14.10 /0 B@:0 @:0 T0:15.99 /0 @0:0 T1:15.99 /0 @1:0
10:44:12.454 : wait
10:44:13.423 : T:15.87 /0 B:14.10 /0 B@:0 @:0 T0:15.87 /0 @0:0 T1:15.87 /0 @1:0
10:44:13.454 : wait
