API send GCode issue
I'm trying to send GCode using the API, everything seems correct to me as im not getting any errors but it just doesn't work.
I'm trying using the demo printer and my real printer:
http://demo.repetier-server.com:4004/printer/api/Cartesian?apikey=7075e377-7472-447a-b77e-86d481995e7b&a=send&data={"M355 S1"}
Is the data properly encoded?
This is what its encoded from:
encodeURIComponent('{"M355 S1"}');
Thanks,
Jungle
  • Ok, so you want to use:
    send
    Parameter: cmd (string) = g-code to execute
    Response
    Sends a g-code directly to the printer.
    Using the direct call to websocket conversion:
    http://localhost:3344/printer/api/<slug>?a=<websocket command>&data=<json object properly url-escaped>&apikey=<API key>>
    Your solution is nearly correct, except data. The json object unencoded would be
    {"cmd":"M355 S1"}
    encoded
    encodeURIComponent('{"cmd":"M355 S1"}')
    %7B%22cmd%22%3A%22M355%20S1%22%7D
    In Parameter description you see the names of the object as well - here "cmd" which you omitted.
  • Brilliant!
    Thanks for the quick response.
