Cannot slice on Windows
I am trying to slice my model (stl or obj) and whatever the slicer I use I get the same error at the end of the slicing:
 error 0x80004005 startwithcreateprocess
I cannot figure out what's the issue. On a previous post it looks like it's an admin problem but I don't think so.
I can launch slic3r manually with no problem
Any help appreciated
  • Can you run configuration of slicer adn slic3r appears? The error normally happens if the executeable is not found. Did you change the settings is slicer manager by adding a new path?
