Repetier server does not load in Windows 10 Pro
edited March 2020 in Bug Reports
i already searched the forum, reinstalled, did a restart and deleted the file „ workdispatcher,sql“  in program data, as described in the FAQ / troubleshooting, but nothing helped.
Repetier server won’t start.  Any help?
Server is a Intel Nuc with windows 10 Pro installed.
repetier Server 93.1
thanks in advance.
*Update, I installed now the previous version, and I have the same result. The sever doesn’t start.
  • Please follow these instructions:
    execute cmd.exe as administrator then run:
    "C:\Program Files (x86)\Repetier-Server\bin\RepetierServer.exe" /c "C:\Program Files (x86)\Repetier-Server\bin\RepetierServer.xml"
    and copy the output to see where it stops.
  • Thank you for the answer. I did run both, first the exe with:
    cd program files(x86) etc, until the corresponding folder was reached.
    Then:
    start repetierserver.exe
    second:
    start repetierserver.xml.
    this is the log I was shown.
    <?xml version="1.0" encoding="UTF-8" standalone="true"?>
    <server>
    <installation-directory>..</installation-directory>
    <storage-directory>C:\ProgramData\Repetier-Server</storage-directory>
    <default-language>en</default-language>
    <port>3344</port>
    <disableIPV6>true</disableIPV6>
    <!-- setting to false can cause problems with external access -->
    <logging>true</logging>
    <backlog-size>1000</backlog-size>
    <update-info-url>http://download.repetier- server.com/files/server/windows/updateinfo.txt</update-info-url>
    <printer-frontend-url>/modules/front2/www/app.html</printer-frontend-url>
    <web-frontend-url>/</web-frontend-url>
    </server>
    Thank you again in advance.
  • That is not what you should do. You should enter this line:
    1:1 - works from any location. Important is just that cmd.exe was started as admin and not as regular user. Only then you see the log required.
  • C:\Windows\system32>"C:\Program Files (x86)\Repetier-Server\bin\RepetierServer.exe" /c "C:\Program Files (x86)\Repetier-Server\bin\RepetierServer.xml"
    Read configuration file C:\Program Files (x86)\Repetier-Server\bin\RepetierServer.xml
    Testing alternative config: "C:\Program Files (x86)\Repetier-Server\bin\RepetierServer-extra.xml"
    Testing alternative config: "C:\ProgramData\Repetier-Server\database\RepetierServer.xml"
    ServerSetting::init()
    Reading server settings...
    11:13:10.885: Webdirectory: C:\Program Files (x86)\Repetier-Server\www\
    11:13:10.885: Storage directory: C:\ProgramData\Repetier-Server\
    11:13:10.885: Configuration file: C:\Program Files (x86)\Repetier-Server\bin\RepetierServer.xml
    11:13:10.885: Directory for temporary files: C:\Users\PC\AppData\Local\Temp\
    11:13:10.900: Reading firmware data ...
    11:13:10.994: Starting Network ...
    11:13:10.994: Active features:0
    11:13:10.994: Reading printer configurations ...
    11:13:10.994: Starting printer threads ...
    11:13:10.994: Starting work dispatcher subsystem ...
    11:13:11.010: Starting user database ...
    11:13:11.010: Importing projects ...
  • That is the last output and then it crashes or what happened then?
    Importing projects reads content of folder C:\ProgramData\Repetier-Server\projects - does it exist and is it empty? Should be empty on a new system.
    Can you also look int C:\ProgramData\Repetier-Server\logs and check for the end in server.log - maybe logging just switched to that file.
    Then nothing.
    this folder exists, but it is empty.
    not sure for what to look, I will send you the file by email.
