How to rename printers folders in Monitor Upload folder
Hello good afternoon. How to rename the printers in the upload folder in Repetier Server Monitor?
I had to reinstall Repetier Server for a corrupt SD. Before I had the printers numbered, now I did the same when I created the new profiles in Repetier Server, I even put a new name to the printers, but Monitor takes the old name and adds an incorrect numbering. Reinstalling Monitor did not work. I think there is some preference left in Windows from the old installation, but I can't find it.
Thanks.
  • Monitor binds server by their UUID. So if you change in global settings->Connectivity the server UUID you can add it again to monitor as new Server, so it should copy the printer names. The printer names are the slug names - the folder names used internally in server - and not necessarily the printer name. When the folders existed when creating them you will get a new name with added number in server!
  • Thanks!
