Z Probe MPCNC
I currently use repetier-host with my mpcnc, I have just added a z probe. The probe works fine but I am at a loss of how I get the software to take in to account the height of the probe. I was advise that I just need to send a g92 z20 command and this should work. I think I am doing something wrong as once probed I can’t get it to lower the 20mm for the probe. If I use the g92 code and the display changes to show -20 but then doesn’t lower when I start the job. I am a completely novice at this so my help would be appreciated.
G30 R0 H20
to tell it that it hits a 20mm material which surface should be considered Z=0 and where you want to be allowed to go 20mm down from.
