repetier server e raspberry 4
good afternoon being that i should change the raspberry, i wanted to ask if repetier server works well with raspberry pi4 thanks
  • Yes works very well. Just note that you need a buster based image to get linux working on it. Our latest image uses buster already, so no problem if you use that.
  • I got it running on a raspberry 4.
    Was excited to see graphing temperatures.  Problem is there is no graph!  What do I need to do?
  • Graphs are at several positions. Regular gui has one in home screen. More exact in Control->Temperature symbol right to filament change icon. In touchscreen GUI it is in "Temp. Graph".
